BBi Autosport Porsche 981 Cayman GT4 StreetCup Roll Bar
Now Available Through Pelican Parts!!!
BBi Autosport's highly anticipated StreetCup 981 GT4 StreetCup Roll Bar is now available through Pelican Parts. Issues such as harness angle, seat travel, and engine compartment access were all carefully evaluated & addressed. Taking a sensible design approach, the bar mounts to frame structure in the cabin and rear strut towers to provide the strongest mounting points and maximum protection. For superior strength and rigidity, high strength 4130 chrome moly steel tubing was used throughout and all joints are meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints eliminates the use of more traditional slip fit tubes with an unsightly through-bolt and nut. The final result is a bar that is clean & functional.
Features
  • Chrome moly steel tubing utilized for excellent strength to weight ratio
  • Modular construction to allow access to engine for servicing without removing entire rollbar
  • Shoulder harness mounting crossbar positioned at appropriate height as per Schroth's instructions
  • TIG welded and utilizes "X" braces on rear section for superior strength and rigidity
  • Mounts to frame structure and rear strut tower to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock or any aftermarket seats on the market
  • Minimal affect on seat travel to accommodate taller drivers
  • Can be used with stock seat-belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even curve
  • Finished in satin black powder coat. Other colors available
  • Bolt-in installation requires no drilling and minimal carpet trimming
Old 04-15-2016, 06:35 PM
Old 04-28-2016, 09:07 AM
View through the left rear quarter glass.
Left driverside bracket through the opening of the sport bucket seats.
Horizontal harness bar
Arch of the main hoop contours perfectly with the headliner
Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These joints allow us to eliminate the more slip fit tubes with an unsightly through-bolt and nut that are common on lower priced bars.
Old 05-03-2016, 03:20 PM
Pictures showing Horizontal Harness Bar Angle As Per Schroth's Recommendations
Seat All the Way Back
Removable Rear Section to allow access to engine for servicing without removing entire rollbar
Symmetrical "X" Section
Rear Shock Tower Mount
- Jerry@BBiAutosport.com
Old 05-03-2016, 03:24 PM
Do you sell the BBi roll bar for the 981 Cayman S? Does anyone have an installation video to get an idea of difficulty level?
Old 09-09-2016, 11:45 AM
Jon we do offer the 981 bar through Pelican Parts. We do not have an installation video and we recommend professional installation.
Old 09-22-2016, 03:51 PM
A few pictures of the bar uncoated to show the high level of craftsmanship that goes into each weld.
Old 01-24-2017, 05:21 PM
Tags
981 , bar , bbi autosport , gt4 , porsche
