door lock
I have a 98 boxster. My driver side window no longer drops down 1/4" upon entry. Reading other forums their is no window play which would rule out the regulator. Is this correct? Is there anything esle I should check for before your recommendation. Thank You Don B
Old 04-24-2017, 09:47 AM
Probably the cable has stretched. You can buy a new regulator or put in a cable adjuster from a bicycle or motorcycle to take up the slack. If you have speakers, take it out and see if the cable housing can be pulled away from the steel post.
Old 04-24-2017, 01:00 PM
