Have a 2002 Boxster S. Have just removed the Becker 220 head unit, and CD changer and installed a Kenwood KMM BT518HD. Used the Metra 70-1787 harness. Incredible sound! But alarm beeps! Just once when locked. Usual double flash when locked but also one beep! Any thoughts, or a cure....?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster iPod Integration and Stereo Head Unit Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 04-04-2017, 11:23 AM
The radio contact in the radio sleeve is touching the radio. You will need to apply a small piece of tape to the area of the radio case that the radio contact arm touches. If you look at the bottom of the CDR 220 you will see the small clear tape...
- Casey
