-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   2001 Boxster S- Problem (http://forums.pelicanparts.com/showthread.php?t=956480)
Dff Moriarty 05-12-2017 12:54 PM
Driving home, temps good and all the sudden big smoke form right rear exhaust. BIG! Blue and white. No leaks and No sign of oil in Water of Visa versa. Runs terrible and won't run under 3300 RPM. Any Ideas what happened.
june82000 05-12-2017 01:00 PM
Very common in these, covered quite a bit here on this forum.
JFP in PA 05-12-2017 02:03 PM
Run a leak down test, you may have cracked a cylinder head. Not at all uncommon.
JackDidley 05-12-2017 09:45 PM
Aos ??
Dff Moriarty 05-13-2017 07:00 AM
Would AOS only blow smoke out of 1 pipe?
Dff Moriarty 05-13-2017 07:24 AM
Can't find any posts describing similar experience here. Can someone please give me a lead.
Dff Moriarty 05-13-2017 02:15 PM
Also noted that smoke clears up at higher rpm. Still just right exhaust pipe. .....?..
