Injector cleaning in Calgary??
Hi,
Does anyone know if there is a place in Calgary that is specialized in Fuel Injector cleaning and flow testing? This place looks awesome for that (but in the US): Witchhunter I got it from: http://forums.pelicanparts.com/showthread.php?threadid=198660 The guys in witchhunt charge $12US per injector but free if it can't be recovered! -J
We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde |
It'll be legen-waitforit
How bad are yours? Just run a couple of cycles of techron through the gas. But change the oil after. Should clean them up fine, especially if you go for a long hiway run.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
I'm not even sure if the injectors were designed to last that long.. But since they're truly mechanical they could last a lot longer than the modern injectors.. I'd really like to see how they were before/after the clean like in this report: ![]() The car is sleeping in Hyma's garage but once I get my garage built I'll start working on it again... -J
I just took a few sets in to a local place in Waterloo, Ontario. Didn't need cleaning after they were flow tested good. Met original specs. Cost to test was $2 each and around $5 each for seal kits.
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 2020 Subaru Outback and 2019 Crostrek. |
