FS: Engines, Engine Parts and Fuchs
It's amazing how much stuff you can collect over just a few years, time to get rid of some of it. There is a few things I didn't take pics of yet, but I can do so if thers any interest in the parts.
Local sales take priority, and all prices in U.S. plus shipping. ![]() 3.0L SC Crank, measured standard on both main and rod journals. $500 3.0L SC Rods, need to be cleaned up and rebuilt, 4 weigh in at 617g, 1 at 616g, and the other at 618g $100 E cams, perfect, with MFI drive $300 2.7L S CIS cams, 3 small pits on 3 of the lobes $30 T cams, 2 sets, early with no MFI drive $30 per set 2.2 T non c/w crank with rods $100 2.2 T cylinder heads, set of 6, non MFI, 46/40 valves, 32/32 ports $250 2.2 T pistons and cast cylinder set with wrist pins, no rings $75 2.0 T Cast cylinders, some look really nice with good cross hatching $25 '71 T engine harness, some of the insulation is kind of brittle, but good connectors $25 Carburator fuel bar, no plating left on it $20 5 blade fan $25 2.7L CIS alusil pistons and cylinders w/wrist pins and rings $50 SOLD 2.7L Distributor, 231 184 007, no points, rotor, cap or condensor, missing one clip $25 SOLD Decent mag chain housings w/covers $25 Mag lower valve covers $10 '69 2.0L T short block, it knocked $100 '71 2.2L T long block, unknown history, no flywheel, engine tin or mount bar, valve cover to valve cover $off the market for now Pair of 16x7 phonedials $30 Pair of 16x7 Fuchs, one is scratched/curbed most of the way around, $100 the other one has a little rash but otherwise decent $150 (mounted with snow tires, will remove) Pair of 16x6 Fuchs, paint has been removed from centers, really nice and no curb rash $450 3 wheel spacers, 2x28mm thick $35 SOLD, 1x21mm thick $15 Thanks Kevin ![]() ![]() ![]() ![]() 2.7 CIS on the left, T's in the middle, E's on the right ![]() ![]() ![]() ![]()
'73 914 2.0L Last edited by Kevins911; 04-30-2009 at 03:49 PM.. Reason: price drops |
'73 914 2.0L |
2.2T P's/C's
'73 914 2.0L |
