Go Back   Pelican Parts Forums > Regional Forums > Canada
Track/Street 1986 Carrera with 1996 3.6 for Sale
I bought this car in the spring from a local Calgary member, he had purchased it and had it setup for track use. I want to sell it as I have a couple other projects going on for which I could use the money and time. It is a well sorted, reliable car which you can drive to and from the track if you wanted to, or switch back to a more street oriented car. When I drive it on the street I get a lot of positive comments from people as even though it has the usual paint rash from running on the track, it is a really good looking car.
1986 911 SC US Imported
Exterior
Rennspeed front and rear bumpers and ducktail
Painted Porsche Arrow Blue aka Acid Blue, L305 Paint in in generally good shape with chips from the track mostly on the front air dam
Remove all AC
H4 Headlamps
Paint Trim Rings
Interior
Remove AC and heat
Momo Steering wheel
Wevo Shifter
Remove fold down rear seat backs
Sparco Driver seat installed
Sparco Passenger seat
Sunroof mechanisms removed
Still has power windows and door locks, all the heating stuff is in place, although no heat hooked up at the moment.
Steering
Bump steer kit
Turbo Tie rods
Installed strut brace
Suspension
Front Torsion bars front 22mm
Rear Torsions 30mm hollow
Bilstein Sports Front/Rear
930 front struts
Weltmeister f/r adjustable sways
ER PolyBronze Front (New this summer)
Offset Camber Plates (new this summer)
Engine/Exhaust and Performance Mods
3.6 Vram Type M 64/21 OBD1 ( Euro vram for manual Gearbox ) from Germany
Steve Timmins Conversion Kit
Mocal front oil cooler.
Custom dual exhaust Magnaflow muffler on 993 HE (no heat at the moment)
Racing Battery
Safety
Installed Bolt in roll bar (autopower)
Installed Cabin Fire Extinguisher
Installed F/R Tow Hooks
Wheels Tires Brakes
8x17 and 10x17 3pc BBS/Fuchs and 235/40 and 255/40 R888/RA1 R*** almost new, RA1 almost done
Longer studs front and back
930 4 piston brakes f+r
Also have a set of Rota’s (7.5 and 9 with 235/255 ) that could go with the car instead of the BBs which would be better for street as they provide more clearance and would fit better if a buyer wanted to move to a more street oriented suspension settings
Bad,
There is one small rust hole in the front driver side tub, up high just by the front, about the size of a loonie, Nothing else I can find
I had to do some hammer work on the front flares to provide more clearance for the tires as they were rubbing with the BBs. That will need to be finished to make it look better, and then perhaps touched up as I am sure some paint will flake off when it is done. I can do the work if someone is interested in the car.
There are also a bunch of spare parts including another good used windshield with seal (current one has a small crack in lower left), a set of rear rotors and a bunch of filters, nuts/bolts and other misc stuff.
Mileage around 104,000 miles. Not sure of total as the the speedo was replaced with with a 160mph (Original included) and the odo doesn’t work, but I doubt it has more than a couple thousand total since that time. Motor had less than 60,000 when purchased and had around 5 years of mostly track time on it. Probably less than a thousand km a year as the previous owner was mostly racing with it, and there are not a lot of events out here. I ran it in around 10 track days this summer.
I want $20,000 Cdn for it. That is firm. Send me an email for more pictures or questions
rvanderpyl at davincibb.net
POictures with Rotas
Picture with BBs/Fuchs
Robert
Currently Porsche less (but the wife has 2)
Old 10-12-2010, 09:27 AM
The part of me that wants a divorce wants this car. Hope it goes to a good home Robert!
Keith - Calgary
1969 912R (911 engine) - Blutorange
Old 10-12-2010, 08:02 PM
Buy the car, WAY cheaper than a divorce
Robert
Old 10-13-2010, 08:14 AM
andrew15's Avatar
This is a sweet deal - 3.6 varioram, 930 brakes, Fuchs/BBS rims - you couldn't build it for this $$!
Robert was within .2 seconds of my times at Racecity in Calgary - with some weight removed, it would definately be a 1.26 car on the full road course.
AM
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 10-13-2010, 01:11 PM
Bump, still for sale, buy it now before spring comes along and I change my mind.
Robert
Old 01-28-2011, 08:19 AM
andrew15's Avatar
Solo 1 is looking like it's going to be more of a time attack setup this year with weight / hp derived classes. That would mean more track time for you Robert.....
In short:
Robert - you should keep it and go Solo 1 again this year
EVERYONE ELSE - this is a great deal
Old 01-28-2011, 11:31 AM
I looked at the schedule for Time Attack, and the things I need to do this year, and they don't fit into the same time/space continium....
Robert
Old 01-28-2011, 12:38 PM
Bump one more time before fall. Buy it now or I will probably turn it back into a street car and do some painting in the winter to fix up the chips, then next spring it will cost more and I'll just sell it to some wieney off Kijji
I will deliver it almost anywhere in Canada if you pay the gas costs for the tow.
Robert
Old 08-19-2011, 12:54 PM
andrew15's Avatar
Saw it last night at the track - still a great car at a great price!
Old 08-19-2011, 01:49 PM
