-   Canada (http://forums.pelicanparts.com/forumdisplay.php?f=246)
-   -   Fun at the track (http://forums.pelicanparts.com/showthread.php?t=547454)
andrew15 06-10-2010 09:02 PM
Fun at the track
Well, did a 1.08.6 at the track in Stratotech this past weekend - slower than a 996 on Hoosier R6s by only 2 seconds and faster than a newer guy in a 996 GT3 :)
http://forums.pelicanparts.com/uploa...1276228882.jpg
andrew15 06-10-2010 09:20 PM
From the top of the car:
http://forums.pelicanparts.com/uploa...1276229891.jpg
speedracer 06-11-2010 07:10 AM
Looks like fun!
rvanderpyl 06-11-2010 07:34 AM
Looking forward to the next event out there, looks like an interesting track.
See you Monday?
andrew15 06-11-2010 08:40 PM
Yup, it's a fun little track
I'll be out Monday for sure.
Here's the video of 2 hot laps
YouTube - Stratotech Hot Laps
rvanderpyl 06-13-2010 07:19 PM
Oops. looks like I won't be there, needed to get the car inspected, Alpine could do that, but I was going over it on the weekend and discovered a crack in the windshield I hadn't seen before. Worse, since I pulled the rollbar that was in it and haven' t replaced it yet, I need to use the regular seatbelts, and the driver side looks like something sharp was dragged across it as it has a shallow cut. SO that needs to be replaced. Oh well, looks like it is going to be another wet one, so I guess I will be out for the next CSCC event instead.
blur911 06-17-2010 06:38 AM
Nice pics and vid. Car sounds good.
Here's some fun at the track I had a couple of weeks ago.
How's this for a big fast autocross?
YouTube - Ultimate Rumble at the Strip, Picton May 30,2010, my last run
haycait911 06-18-2010 09:38 PM
hey Andrew, nice hood, but how about a couple of pics of the rest of the car?
andrew15 06-20-2010 02:57 PM
Here's the rest of the car :)
http://forums.pelicanparts.com/uploa...1277070735.jpg
http://forums.pelicanparts.com/uploa...1277070796.jpg
http://forums.pelicanparts.com/uploa...1277070991.jpg
Canada Kev 06-20-2010 09:53 PM
Awesome shot.
andrew15 06-20-2010 10:32 PM
Those two action shots were taken by a guy at an open track day - he basically shows up with some great equpment, shoots all day and sells a cd of the images for $20.
I think he's a university student, so $20 x 30 or so cd's isn't a bad way to earn some scratch :)
I'm going to another day on Tues - supposed to be a bit rainy, so I hope to get some interesting shots.
AM
Here's one of Roberts Carrera from the same day:
http://forums.pelicanparts.com/uploa...1277098306.jpg
rvanderpyl 06-21-2010 07:05 AM
Tuesday? Any openings?
Jim2 06-21-2010 10:59 PM
So Robert, how's the 911 on the track?
rvanderpyl 06-22-2010 05:51 PM
It is good, but the cut-out switch has to go, the current fine track conditions are vibrating the connections loose and causing the engine to cut-out at least a couple times a day. I needed to weld the muffler back together as it was cracking, and I think I need to go over the front end, as it had a pretty bad knock by the end of the day.
But overall it is a lot faster than anything else I have had out yet. I can (mostly) stay with Andrew :)
Jim2 06-22-2010 08:45 PM
Intermittent cut-out occurred a couple times but neither Rick or I could find anything obvious.
Check the steering rack bushings on either end of the rack. One bushing had popped out and was producing a knock. The late 80's racks have a circlip versus the early racks which use a friction washer. If the bushing gives you grief keep your eye out for later rack. Our "local" used parts warehouse may have one.
rvanderpyl 06-23-2010 08:14 AM
Well I ended up finding a loose, and then broken as I moved it, connection to the resistor. So I removed it for the day as I didn't really expect to use the switch to kill the engine, and I think that is there for alternator protection ? I am going to jack the car up today and go over everything, as well as bleed the brakes, so I will check the bushing. I had one 'off' so that may have contributed to some looseness
