-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Replaced fuel filter, no fuel getting to engine (http://forums.pelicanparts.com/showthread.php?t=1015570)
Dazed 12-14-2018 06:54 AM
I replaced the fuel filter on my Mini Cooper 2006 R53. What I guess is a pump buzzes for 2 or 3 seconds then quits when I turn on ignition. No fuel is getting to the engine. Any ideas what it causing this?
scooters garage 01-18-2019 01:41 PM
I had the same problem ,I found that I didn't have enough gas ,I added a gallon to the tank and the car started up instantly. The buzzing noise you hear is a good noise, if you don't hear it your fuel pump is probably bad.
