-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   coolant leak (http://forums.pelicanparts.com/showthread.php?t=508291)
macbob1a 11-01-2009 02:01 PM
coolant leak
i have a coolant leak that seems to be coming from or behind the oil filter housing.
can't see for all the stuff around it. a mechanic told me that if i replaced the oil filter housing it would take care of the coolant leak and the very small oil leak i have in the same area.
looking forward to all the help i am used to on here
Bob
Ricochet Rabbit 11-16-2009 03:01 PM
The O ring in the housing may have got messed up when someone replaced the filter (happened to me, own stupid fault) and replacing it will probably fix the oil leak. But no way is that going to fix the coolant leak.
Wyvern 11-16-2009 08:05 PM
If it is a first gen MINI ...there is a small oil cooler that is at the base of the filter ... but no coolant there.
What gen ? and Are you in a Cooper or a S
Go to realOEM.com and you can see the parts break down
Or if you want some other resources just PM / email me
