Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Brett (guest)
Guest
Posts: n/a
25ft/lbs for the OEM 6mm bolts is way to tight- One of the heads broke off! Tried to use an EZ Out removal tool but it broke off in the damaged bolt so now it's going to cost a lot of money & time to fix.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Convertible Strut Brace Install - R50 MINI Cooper (2003-06) - R53 MINI Cooper S (2003-06)
Old 05-21-2012, 09:15 AM
