-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Question on Crankshaft Pulley Replacement (http://forums.pelicanparts.com/showthread.php?t=691123)
brett jameson (guest) 07-26-2012 01:01 PM
I have a 2004 mini cooper s, holding the brake pedal, ignition in position 2, and having it in gear does not stop the crank from turning. I understand using the screwdriver and m6 bolts in pulley to stop rotation and get bolt out/pulley off, but how can you stop the crank from moving when installing new pulley???
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Crankshaft Pulley Replacement
Nick at Pelican Parts 07-26-2012 01:01 PM
You brace the pulley as you would when removing it. The bolts and bar, wedged against the vehicle body should stop it from turning. Here is an image from the procedure: http://www.pelicanparts.com/techarticles/MINI/11-ENGINE-Crankshaft_Pulley_Replacement/images_small/pic03.jpg
- Nick
