Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Alan (guest)
Guest
Posts: n/a
I recently replaced the bearing on my cooper s tensioner pulley assy
I found that I only had to remove the top engine mount assy and then the
Belt tensioner was abled to be jiggled out, also I just used a 600 mm
Approx piece of 25/25angle iron with a small cut out on one side and it
Worked fine for detensioning the spring,TIP be absolutely sure to put belt on correctly,
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Belt Tensioner Replacement
Old 05-07-2013, 04:10 AM
Nick at Pelican Parts's Avatar
Thanks for the feedback and tip.
- Nick
