Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
JOHN (guest)
Guest
Posts: n/a
can i add a fuel filter under the hood near the motor my mini 50 runs good at higer rpm but rough at idle engin lite shows #4 CYL HAS SOME ELEC PROBEM TKS
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Fuel Pump and Filter Replacement
Old 05-07-2013, 04:50 AM
Nick at Pelican Parts's Avatar
If the filter is properly mounted it shouldn't be an issue to add one. However, fuel supply problems generally do not show up at idle and not off idle. I would look for other causes for your problems also. Vacuum leak, ignition issue, etc.
- Nick
