Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Qi (guest)
Guest
Posts: n/a
I just received the plates...From the PDF instruction on madness motor works's website, it says I need to remove sway bar end link, but pelican's instruction didn't mention it. Is that something I have to do in order to lower the strut assembly? mine is R50. THANKS!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Strut Tower Reinforcement Plate Install
Old 06-06-2013, 04:59 AM
Nick at Pelican Parts's Avatar
The sway bar end link is attached to the strut. Removing it allows the strut to drop down much easier. I would do it to save yourself the struggle.
- Nick
