-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/showthread.php?t=781607)
Notamecanic (guest) 11-14-2013 12:52 PM
Well for some reason my question didn't post. .. Now my ep light went off and it's in limp mode 3 gear. So I took it to the shop they told me. They can reset the trans control module. So after I paid 125 bux for them to reset the computer. Still won't shift .. Took it to another shop where they let me use there lift. Seems to have a leak from the black pan under the trans Seems like the gasket is blown out What do you think is a good price. To have this repaired ???? Replace gasket and fill it with new fluid ???
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 11-14-2013 12:52 PM
I cannot comment on price, as I haven't seen the issue. You can get a detailed estimate, then call around to different shops to compare the price.
- Nick
