Can you repair the power steering
Pump with out replacement with A new one __________________ This post was auto-generated based upon a question asked on our tech article page here: |
There are rebuilt units available. I would suggest replacing it with a new or rebuilt unit.
- Nick |
There are certain "repairs" on the pump that are fairly easy. Let's say you have a pump that started having intermittent hydraulic supply issues - power steering goes well and suddenly bad - and it changed into becoming a permanent issue...
This can be caused by the following sceanario: - The electrical pump has 4 static carbon brushes/blocks sitting on the rotor - these brushes are having slight contact to the rotor to ensure electrical connectivity - they are approx 2/3 inch long and spring loaded to maintain the contact to the rotor - by time, the brushes/blocks wear and thus thus carbon dust is created - the dust is conducting and stays contained within the electric motor of the pump - thisin turn can cause shortages and the electric motor thus the pump to fail What to do: - Open the electric motor of the pump and removecthe dust with a vacuum cleaner - check that the brushes/blocks have still material left - if not, they can be replaced ( I asked the question about part number a few weeks ago - no reply) After removing the dust, I reassembled the pump keeping the old brushes and since then it works fine. i would say that this is a very common scenario for the pump failure and the main job for the pump rebuilders (incl brush replacement) |
| All times are GMT -8. The time now is 08:02 AM. |
