Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
The Dude (guest)
Guest
Posts: n/a
My Mini 2007 S my mini is loosing fuel pressure in about 4-6hrs of sitting making it hard to start There is no fault indicator coming on as well. Replaced the fuel pump to fix it but that didn't seem to work, is there any problem areas to check that might cause the drop in pressure?
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-11-2014, 04:03 PM
Nick at Pelican Parts's Avatar
Which fuel pump did you replace and where are you performing your fuel pressure test (connection point)? How are you activating the fuel pump to test it?
- Nick
