Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
o2bnkc (guest)
Guest
Posts: n/a
I just replaced the battery and the car starts fine, but the check engine light is on. What's up with that? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-03-2014, 03:24 PM
Nick at Pelican Parts's Avatar
DOn't know, maybe a part failed, coincidentally. I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
