Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Reg (guest)
Guest
Posts: n/a
Hi. I have a 2003 MINI Cooper not an "S". I had the radiator replaced, and after getting it back from the shop, I noticed that the radiator itself has some "play" in the mounting. Is this normal?...Should the radiator be solidly mounted, so there is no play or movement? Please HELP!
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-20-2014, 12:49 PM
Nick at Pelican Parts's Avatar
It is mounted in rubber grommets, so a small amount of movement is OK.
- Nick
