-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Question on Fuel Pump and Filter Replacement (http://forums.pelicanparts.com/showthread.php?t=841190)
Xmun (guest) 12-03-2014 07:09 AM
Hello,
I recently changed the fuel pump on a 2002 Mini Cooper S R50 I believe . Although the pump works fine, the gauge won't go below the one quarter mark. When I partially remove the pump from the tank and manually move the arm, the gauge does move through its full deflection. Could there be an issue with the sender unit, or did I install something wrong ?
Thank you
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 12-03-2014 07:09 AM
The sender may be jammed in the tank. Check if the fuel pump is orientated correctly.
- Nick
