Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
lowpuller (guest)
Guest
Posts: n/a
My 2010, R57 I think, has cold start issues. After it has been sitting for several hours upon starting it idles very rough, the accelerator is even non responsive. It a few seconds of this the check engine light cones on. If I shut down and retry, car starts perfect and runs great. Codes on CEL reveal misfire. Mini recommended carbon cleaning, which I had done, but it made no difference. If anything the problem is worse? Thanks for any suggestions you have.
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-09-2014, 07:20 AM
Nick at Pelican Parts's Avatar
Could be fuel delivery issue or base engine problem. It sounds like an engine misfire. I would check spark, fuel and compression on all cylinders.
- Nick
