-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Question on Fuel Pump and Filter Replacement (http://forums.pelicanparts.com/showthread.php?t=842045)
Drofenal (guest) 12-09-2014 07:17 AM
I replaced the fuel pump and my MINI ran great for 2 weeks then it died again, same problems as before. It happened after I filled the gas tank up. Could it be the gas? Or a faulty gas pump? This is the second time this has happened. Im wondering if I should fill the tank up all the way or a little over 3/4.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 12-09-2014 07:17 AM
Have you confirmed the fuel pump is faulty? I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick
