-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/showthread.php?t=848938)
Ron (guest) 01-27-2015 09:37 AM
I have a 2003 Mini Cooper R50 Automatic transmission. Is the process the same for my type of transmission as this? I didn't find an overflow tube inside after I removed the plug
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 01-27-2015 09:37 AM
The article you commented on is for manual transmission.
This one is for automatic:
http://www.pelicanparts.com/techarticles/MINI/28-TRANS-Automatic_Transmission_Fluid_Change/28-TRANS-Automatic_Transmission_Fluid_Change.htm ] http://www.pelicanparts.com/techarticles/MINI/28-TRANS-Automatic_Transmission_Fluid_Change/28-TRANS-Automatic_Transmission_Fluid_Change.htm [/url]
- Nick
