Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
FixItPlease (guest)
Guest
Posts: n/a
R53 - replaced slave cylinder after noticing fluid coming from around the boot. We've bled it several times as instructed with plunger compressed. We've also bled it installed from the bottom up with the oil can technique. Nothing we do gives us a usable clutch. Still goes to the floor and barely actuates the clutch. Do we just keep bleeding? Is this an air bubble symptom?
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-20-2015, 05:40 AM
Nick at Pelican Parts's Avatar
You may have a faulty master cylinder, as it sounds like you tried all methods.
- Nick
