-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/showthread.php?t=852550)
Tylerfullerton (guest) 02-20-2015 05:41 AM
After I bleed the slave cylinder it doesn't want to hold the pressure I put on it from the clutch pedal, the second I press it it shoots out the tube connected to the slave cylinder, made sure I put the rubber nipple back on and everything...
http://www.pelicanparts.com/more_inf...68306-5152.jpg
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 02-20-2015 05:41 AM
The line shoots out? The slave or line may be damaged. Inpspect the line groove where the clip sits.
- Nick
