Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mike (guest)
Guest
Posts: n/a
Installed new pressure plate, clutch, fly, and throw bearing. I did not change the slave, but when I disconnected it from tranny I did not compress it while it sat off to the side. Now, tranny is back up but when I push the clutch it is extremely soft for the first half, then it gains some resistance to the floor. Does this sound symptomatic of needing to bleed the slave? Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Replacement
Old 11-11-2015, 09:41 AM
Nick at Pelican Parts's Avatar
I would try bleeding the hydraulic system. If that doesn't do it, to you may need to replace the master and slave.
- Nick
