Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
ContentGenerator (guest)
Guest
Posts: n/a
When starting my R53, I do not hear the fuel pump initiate when putting the key in the ON position which I used to. I think there may be an electrical problem. I've checked the fuses, and they're fine. Before ordering a new fuel pump, how do I check the electrical connections? And if it's a electrical line that might have corroded, what parts would I need to order? Thanks!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Fuel Pump and Filter Replacement
Old 11-25-2015, 08:27 AM
Nick at Pelican Parts's Avatar
When turning the key on, check for power to the fuel pump. If power is present, the fuel pump is faulty.
You won;t know what to order until you determine what is wrong.
- Nick
