Guest
Posts: n/a
Do I need replace filter?
I think it is metal mesh, So, Is it possible reuse after cleaning? __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Automatic Transmission Fluid Change |
If you remove it, replace it. The seal will be worn and may not seal correctly again.
- Nick |
