Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Jimmer (guest)
Guest
Posts: n/a
I've just removed the driver's side left rear window regulator in a 2006 MINI Cooper convertible, and discovered the white nylon block into which the up and down cables anchor split and allowed the motor/transmission to destroy the two cables. Are the white block and cables available anywhere, to avoid purchasing an entire regulator assembly? Bentley has a good online article describing the procedure for rear side windows on the MINI.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Window Regulator Replacement
Old 02-12-2016, 06:28 AM
Nick at Pelican Parts's Avatar
I am not sure if the part is available. I’m not the best with part numbers.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
