My 03 mini s 6 speed manual trsnny started slipping at high rpms. What could cause this. Also the cat which is built into the end if the exhaust header is leaking and loud. Meinike quoted $1000.00 just for exhaust assembly. Any known patches?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Manual Transmission Oil Change |
You can't patch exhaust.
First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing. - Nick |
Couldn't this be the Clutch slipping on the flywheel? it sounds like what mine is doing in my 05 Cooper S also.
| All times are GMT -8. The time now is 10:32 PM. |
