-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/showthread.php?t=907347)
Moniga (guest) 03-23-2016 11:02 AM
I have a 2006 Mini Cooper that won't shift into first gear but will for the other 4 5 speed manual trans and shifts into reverse. Any ideas what might be wrong before I take it in?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Manual Transmission Oil Change
Nick at Pelican Parts 03-23-2016 11:02 AM
The cables may be faulty. Check the movement at the trans, see if the shift linkage moves along with the shifter.
- Nick
