How difficult is it to change the front brake caliper rubber dust boot? Do you need to take the caliper apart?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Front Brake Pad Replacement |
You need to remove the piston. We use to replace them on vehicle a long time ago. Remove the caliper, then use low pressure air into the caliper hose fitting to push the piston out. Replace the O-rings too.
- Nick |
| All times are GMT -8. The time now is 01:44 AM. |
