-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   R56 Broken thermostat electrical connector - Replacement part FIX! (http://forums.pelicanparts.com/showthread.php?t=911943)
Luccia at Pelican Parts 04-26-2016 02:16 PM
I've seen more than a few times where this issue has popped up so I wanted to share some part information with everyone. As you know, a lot of plastic components under the hood of MINI's can get brittle and break. Recently, I've seen more than a few individuals indicate that their R56 thermostat coolant temp sensor connector has broken, but there is no listed part number for that connector. From what I have found, the oil pressure connector is the SAME as the thermostat coolant temp sensor connector. The 2 pin plastic connector for the oil pressure connector is part number 12-52-7-542-850-BOE HERE, which is #13 on the image below:
http://cimg6.ibsrv.net/gimg/www.nort...6011c8419b.png
This is what it looks like.
http://forums.pelicanparts.com/uploa...1461705204.jpg
Along with that connector you will need 2 of these wires 61-13-0-005-199-M9 HERE. Image of one of them below. You will need to splice them into the wiring harness.
http://forums.pelicanparts.com/uploa...1461705300.jpg
Hope this helps someone with this issue in the future. Let me know if you have any questions.
Dave at Pelican Parts 04-26-2016 05:11 PM
I wonder if the connector can be de-pinned (I see a retaining tab on the upper side of the pin in that photo) so that you don't have to cut and splice?
Unfortunately, I don't know exactly what the de-pinning tool would look like--but it might be as simple as a very thin flat blade...
--DD
Luccia at Pelican Parts 04-27-2016 09:14 AM
--DD
I'm not sure, but I've seen a few with broken pins. If theirs are fine and the plastic connector is the only issue, it may be good to investigate if what you're saying is possible and then all they'd need is the connector.
Nick at Pelican Parts 09-26-2016 12:23 PM
To remove the terminals from the plastic connector, first remove the grey plastic piece from the connector. It unclips. Then on the terminal, use a small pin to press the retaining tab (red arrow) to release the terminals. Then I would butt connector and heat shrink the wires if replacing the terminals.\
http://forums.pelicanparts.com/uploa...1474917759.jpg
jsuderman 07-25-2017 08:27 PM
update?
any update on weather you need to splice the 2 electrical wires? I broke the socket housing that connects to the VANOS Solenoid. i have the socket housing and bushing contact. just want to know weather i need to slice or crimp the bushing?
Luccia at Pelican Parts 07-26-2017 08:14 AM
Hello - If the terminals are bad and you need to replace those along with the socket housing, you will need to cut in the new wires. Nick's recommendation above is:
You only need to cut in the new wires if your terminal ends are bad (you can butt connect them as Nick recommended or twist them together and solder them). If they aren't, you can just remove the old socket housing and put the new one over the wires. Follow Nick's directions above if you do not need to splice in new wires.
jsuderman 07-26-2017 09:00 PM
Hi
Replaced the socket housing but now getting a p0013 and p0016 code. Is that related to the wiring?
Luccia at Pelican Parts 07-27-2017 09:11 AM
Yes, P0013 could be related to a wire issue for the VANOS. Go over your install and make sure that the connectors are not pushed into the housing too far. Make sure they're making a good connection and aren't sliding back and forth in the connector. I'd look over the wires/your install job and make sure everything is in working order. Fix anything that looks obvious and then clear the codes. See what comes back.
jsuderman 07-27-2017 09:57 AM
Will do. Just a quick question. To replace the plastic housing, I just pulled out the two bushing wires and inserted them both into the new housing. Is that the proper way to install ?
Luccia at Pelican Parts 07-27-2017 12:04 PM
If the wires weren't damaged, then putting them into the new housing should have been fine. Did you remove the grey plastic piece from the connector and then put the new wires in and put the piece back on? Make sure the wires are in there nice and fit, you can see the retaining tab on them at Nick's post above. That should hold them into place in the connector.
jsuderman 07-28-2017 01:20 PM
Great! I took it to a mechanic because i felt it was over my head with the electrical aspects. Of course something else was wrong so i had them change the timing chain. around $1500 repair. Got a call now that the exhaust solenoid needs work. I just had it changed at the dealer a year ago. Do you think i'm getting error codes because of the wiring? Could it be a actuator?
Luccia at Pelican Parts 07-28-2017 01:36 PM
Did you take it to a qualified MINI independent shop? What was the exact P code he told you it was? P0013?
P0013 0x2842 VANOS exhaust-side solenoid valve, control-activation Open circuit.
Have him check over the wiring to the VANOS to make sure nothing was damaged during the replacement. I have seen an individual report this code with issues with the wiring. This could or could not be your cause. What year R56 do you have? Cooper S or Cooper Base? Depending on your MINI info, if you have a R56 N12, N16 and N18, you can swap your intake with your exhaust solenoid to test to see if your exhaust one is bad. If not, you can also try and clean it. This article can help: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
jsuderman 07-28-2017 04:21 PM
my car is 2007 mini cooper. base model. Im guessing N12 engine. I asked them to check the code out but they just reported that the VANOS solenoid was bad. They said they would swap out but said they would charge. I was already on the hook for $1500 so i thought i could do that myself. IT just curious because when i started this process, there was nothing wrong with the exhuast vanos solenoid and now i change the plastic housing. now i need a whole new one? doesnt make sense to me
and yes p0013 is the code that was given and that my own personal reader has
jsuderman 07-28-2017 05:08 PM
Update: inspected the wiring. looks good to me, although i dont quite know what im looking for. No cuts or abrasions. I did have to pull rather hard to release the two wires from the housing. it may have stretched out a bit. i have wires going into the right slots but does it matter which way the bushing enter the housing? I still need to swap out the Vanos solenoids for further research.
jsuderman 07-28-2017 05:10 PM
Also: my wires dont have that black stopper. just 2 wires. does that make a difference?
Luccia at Pelican Parts 08-01-2017 08:51 AM
I'm not sure if the stopper makes a difference, but it could help keep them in position. Go to this article: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article and leave a comment at the bottom. Nick will have additional input for you about the issue.
airheadearl 09-15-2017 03:56 PM
Hi, I just replaced both my oil pressure switch and Coolant temp sensor connectors using the above listed parts. Thanks for the information.
I would like to point a couple of areas where my experience differed:
1st: The 2 connectors are not exactly the same. The grey portion has a key which is visible in the photo below, and they are mirror images. You can shave the key off the plug with a razor to make it fit in the CTS, or re-use the grey part from your old plug (which is probably broken).
The grey part can be released by gently prying between the grey and black parts, I still ended up breaking one of the retaining legs...but it still works. (Also, the plug is shipped with the grey part halfway installed, don't push it all the way in until your wires are installed)
The black cover on the back is hinged, and released by poking the slots on the sides, while lifting up.
2nd: The wires listed are not the correct part, they are too small.
I suspect the correct part is 61-13-0-006-665-M9, but I don't know, I had to use my old wires.
RealOEM only tells you the right contact, but not the pigtail, and I don't know how to cross-reference them.
airheadearl 09-23-2017 11:02 AM
Correction to the above: Looking at my old parts I see the CTS plug has a green plastic tip...so they are color coded for the keyways. Looks like you can have green, gray, or blue. The connector should really come with all of them.
Warren28 06-30-2018 02:05 PM
I replaced the the housing socket with a local dealer part (mine was p/n 12527542849). As "airheadearl" said, the plastic was keyed differently and I shaved off the key and it worked. I was able to reuse the existing wires.
What fooled me was how to properly seat the wire connector tabs. It was easy to feed the wires through the silicon watershield, but it didn't realize the bottom of the socket pulls gently apart lengthwise and then you put the wires in, and then slide (with a click sound) it back together.
vhsnap 09-09-2018 06:37 PM
Hi,
I know this thread is old, but could you tell me which wires should go in which port if the key side is facing towards you? There's a yellow wire and a white wire, and I don't want to cross them.
Thanks! :)
vhsnap 09-09-2018 06:43 PM
Hi,
I know this thread is old, but which wires go in which port if the key side is facing you? There's a yellow wire and a white one, and I don't want to cross them by accident.
Thanks!
Luccia at Pelican Parts 09-10-2018 04:35 PM
I am not sure. Best bet is to look at how the old connector is hooked up and make sure to hook up the new connector the same way.
mbmb77007 06-18-2020 01:47 PM
61-13-0-005-199-M9 is the wrong part. The terminals for the temperature sensor connector are
BUSHING CONTACT(m) Part #: 12-52-7-543-260-BOE
or
Bushing Contact(Mini)(m) Part #: 12-52-7-555-721-BOE.
They are the same, except that the -260 part has an extra flag that needs to be trimmed off (and costs a little less).
You will need to strip the end of the old wires, and crimp the terminal on. Study the connector first, and make sure the parts of the connector that are behind the terminal are there before you do your crimping. The crimper I use is something like this. Avoid crimping the rectangular part of the terminal, and it should snap right into the connector.
It doesn't matter, functionally, which wire goes where—the sensor is a variable resistor, and the resistance is the same whichever way you measure.
MB
Vanski 08-30-2020 05:24 AM
Thank you so much Luccia on the alternative plug for the coolant sensor. Your oil pressure plug works like a charm.
Luccia at Pelican Parts 09-01-2020 02:20 PM
Terrific! So glad this could help you in a time of need. :)
Vanski 09-17-2020 06:25 AM
Question on reverse wiring on ECT sensor:
Are there any impact on reversing the 2 wires that is leading to the ECT sensor? I got a new ECT sensor that came with my new thermostat and housing, replaced the plug and wiring as mentioned above and now I'm getting DTC code of P0117. Wondering if new ECT sensor can be defective. I still have my old sensor and was wondering if I should stick with my old sensor. Any thoughts on fixing the P0117?
Vanski 09-21-2020 03:03 AM
Bad ECT Sensor Wiring
Luccia or anyone else,
I have a P0117 and it's telling me that I have a low circuit input on my ECT sensor. I have a brand new ECT sensor, wires and plug connector which I bought using your suggestion from you earlier comments. I even tested the new ECT sensor just to make sure that it is not defective and it works fine. My OBD II machine is telling me that "I HAVE A BREAK or GROUNDED wiring" for my ECT and was wondering if there is a wiring harness I could buy that leads to my ECT sensor from the DME terminal OR could someone tell me which pin number on the harness or DME so I could run a new wire that would bypass the break or grounded section in order for my DME to pick up the signal again. Could you help me? That would be great if you can.
http://forums.pelicanparts.com/uploa...1600682441.jpg
Rudedawg1951 12-06-2020 10:40 AM
Hi all, just joined the forum, and have lots of questions on a 2008 mini cooper hatchback, r56,N14
replaced t-stat housing, forgot where the 3 plug sensors go??? one for temp, one for t-stat, one for oil.
One has a green spacer ( for lack a better word ) another has a grayish spacer, only one has single wire going into the connector, I know I should of marked them first, but being in a hurry, I did not, so I am here looking for HELP If you can be so kind as to not mention my not marking them or taking pics I'd appreciate it.Seems weird that a plug has only 1 wire going into it??
Thanks in advance for any help you can offer RUDY
Vanski 12-06-2020 03:39 PM
Originally Posted by vhsnap (Post 10175182)
Hi,
Thanks!
If you're looking straight down at the sensor, the Yellow wire goes on the left. Yes it does matter if you have the Yellow wire on the right side of the plug. I know this because when I had the wires reversed, the computer read the ECT as 284 degrees Fahrenheit even when my engine was stone cold. So yes, it's important which wire goes where.
bquist 12-21-2023 09:45 AM
Coolant sensor connector
Just wanted to point out this connector does not work on 2013 Mini Cooper. The plug is too big and key is oriented wrong. Unfortunately, I did not find this out until receiving the part and tried to use it. Pretty sure my son's hatchback is an R56.
