Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
saguaro (guest)
Guest
Posts: n/a
Transmission oil cooler leak
I'd like to add one more leak. I found leak in transmission fluid cooler Mini Clubman S R55. There are screenshot below, you need to replace two orings to stop leaking. Fluid is leaking when fluid is hot and you accelerate fast :
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Oil Leak Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article
Old 03-28-2017, 01:53 PM
Very cool! Thanks for contributing. We appreciate the value that you add to this posting by sharing your experience with the Pelican DIY community. Nice work!
- Casey
Administrator
Luccia at Pelican Parts's Avatar
Good info. Additional info: The transmission oil cooler is on these vehicles:
For the automatic transmissions ONLY. If you have a manual you do not have this part.
24-11-7-551-093-BOE o-ring here: Pelican Parts - O-Ring
24-11-7-551-094-BOE o-ring here: Pelican Parts - O-Ring
Old 03-29-2017, 09:40 AM
