Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
pipe (guest)
Guest
Posts: n/a
hi i have a p0341 fault code on my mini cooper s 2010 i believe its a camshaft sensor issue but which one is it with this code inlet or outlet pls
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 08:13 AM
Nick at Pelican Parts's Avatar
That should be the intake camshaft sensor. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Depending on your MINI FC code this is what your fault is pointing to:
P0341 0x2968 Camshaft Position Sensor 'A' Performance (Bank 1)
P0341 0x2D9F Intake camshaft sensor: Single implausible
Your R56 is an N14. Therefore, there is only an intake camshaft sensor. You can test it using this article here: MINI Cooper R56 Camshaft Position Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article.
Old 04-26-2017, 09:05 AM
