Guest
Posts: n/a
I have recently purchased a 2003 Mini Cooper. I am changing the oil and ran into a problem. The oil filter housing is the earlier style with the spring and the cage. I bought a new filter element that was supposed to be for the 2003 Mann HU 816/2x and it doesn't fit over the cage. It looks like the filter element is for the new style housing no cage/spring. I can't figure out what filter I need to use - all the parts sites I have looked at seem to only specify the new filters. Help! I need to find the filter that fits the old style housing. Thanks.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Oil Change (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
You can remove the spring and cage. Later filters have the cage built into the filter. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick |
