Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Bobdod (guest)
Guest
Posts: n/a
What would be done differently if you have an automatic transmission? Do you do the job with it in neutral? It's there a need for the flywheel locking pin? Does the automatic transmission have a locking pin slot?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-09-2017, 07:03 AM
Nick at Pelican Parts's Avatar
what makes you ask this? Where did you see this stated?
- Nick
