-   MINI Discussion Forum (http://forums.pelicanparts.com/forumdisplay.php?f=229)
-   -   R56 Heater blower motor issue (http://forums.pelicanparts.com/showthread.php?t=975015)
gjslutz 10-23-2017 09:06 AM
2007 R56 Hatchback with automatic heat control.
I replaced the Final Stage Unit (Blower Regulator) Blower still will not turn on.
If I bring the power on to where the auto control lights up, I can change the speed and temp. on the screen. Still no blower action. If I unplug the power at the blower and jump it with 12V, it will run.
If I power off the car, and unplug the blower motor. Then power up the car to where the control screen lights up. I can plug the motor to the power lead from the regulator, the motor will then run and I can control the speed from the screen on the control screen.
If I shut the power off and then power it back up, no action till I do the above again.
Looking at my Bentley manual. It shows an K4 heater blower relay in the A4010 junction box.
What & where would I find that. How to ID it?
I used my volt meter to check the voltage on the regulator pins 1 through 4 and all looked good per what was shown on the blower regulator test section, unless I missed something.
Gary
gjslutz 10-24-2017 03:58 PM
It was loose wire on regulator pin 3. all is now well.
garagodaisuke 10-26-2017 07:00 AM
Good thing you found the missing piece
Luccia at Pelican Parts 10-27-2017 09:33 AM
Glad you figured out the issue, Gary. Thanks for reporting back with it as it may help someone else out in the future.
