2007 r56 n12. have an issue with no pressure at 1st start of the day, and rough idle, like a chugging sound when trying to move forward or reverse. i have to usually leave it on the ON position to prime, and wait for the rpms to settle down a bit before moving.
using a pressure gauge w/car running, pressure would be at 54psi, but when off it would drop quickly past 45psi. i replaced the fuel pump and filter. tested the pressure, this time it stayed around 48psi after 20 minutes w/car being off. from the manual and your article, it shouldn't go past .5 bars. but i still get the rough idle. i couldnt find any apparent leaks around the fuel rail/line or under the car. does the fuel rail have a check valve or is it only the pump? could it be the fuel pressure regulator on the filter unit? also need to mention that i replaced the fuel injectors a couple months ago but can't recall if i had the rough idle before that. i bought the car a month before i replaced the injectors. thanks in advance __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Pump Testing (2007-2011) | Pelican Parts DIY Maintenance Article |
Cycle key so it reads 54, then restrict like at soft rubber section using hose clamping pliers, keep at 54, does engine start right up then stall?
- Nick |
| All times are GMT -8. The time now is 08:31 AM. |
