Mazda's engine development
Sounds weird to me...kind of a gas engine, but semi diesel design?
https://www.caranddriver.com/reviews/2019-mazda-3-with-skyactiv-x-compression-ignition-gas-engine-prototype-drive-review
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Engineering explained always does a good job braking down new car tech. "lean burning" gasoline engines has been one of those techs that have been pursued forever. It seems mazda has commercialized it for at least part of the engines operating conditions
https://www.youtube.com/watch?v=yNSxow3W7ek
84 930 18 Cayman GTS |
Not a new concept, but Mazda seems to be able to make it work commercially.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Unregistered
A friend of mine had one of those in high school. Darned thing would ping like crazy every time he pushed on the gas.
Took 30 seconds to shut down after he turned off the key too! |
The Stick
Mazda goes mmmmmmmmmmm
They have been calling their variable cam timing SkyActive for some time now. My general description is it's load based variable cam timing with mixture and ignition to match. Friend as a year old Mazda 3. It does pretty well. Seems to have plenty of power when needed and gets great gas mileage cruising.
Richard aka "The Stick" 06 Cayenne S Titanium Edition Last edited by RKDinOKC; 07-30-2018 at 11:44 AM.. |
canna change law physics
Ford is doing an Achates opposed Piston engine. The plan is to make a 2.7l engine with 42-45% thermal efficiency. This will mean mileage in the 40+ mpg range with a Ford F150, on gasoline.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I'm with Bill
A lot of the articles refrain from speculating on gas mileage, I think I read to expect Prius type of gas mileage, like 50+ MPG with 60 MPG not out of the question.
If they hit that mark it will be a game changer.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
Did you get the memo?
30% improvement would be pretty substantial. Mazda is such a cool company, the smallest of the Japanese manufacturers but possibly the most innovative.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Variable compression, right?
David 1972 911T/S MFI Survivor |
Control Group
45% thermal efficiency?
She was the kindest person I ever met |
Almost like a common rail.
I like
dolor et pavor Copyright |
Ooo? What’s the timeline on that. I’ve been saying I want an f150 sometime in the next 5 years.... |
Carnot Cycle! About the only thing I remember from my ME classes.
White and Nerdy
(the shotguns)
so I read the first few paragraphs and I'm not clear on what's new here?
mazda wanted to use compression only to ignite an ultra lean fuel/air mixture but it wouldn't work so they brilliantly introduced spark to the mixture and boom, skyactiv x!
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
It's both a compression and spark ignition engine, and goes between the two modes depending on load. Best of both worlds between a diesel and gas engine, but using gas and at a cost comparable to a standard gas engine.
White and Nerdy
A fission bomb creates the environment for a fusion bomb to go off. The combustion chamber has a fuel/air ratio for compression ignition. A precise second direct injection fuel pulse creates a small area near the spark plug that fires off like a conventional gasoline engine, this explosion raises the compression of the remaining leaner fuel/air in the cylinder and allows it to combust from compression rather than ignition spark. Did that make sense? |
(the shotguns)
it this really a variable compression engine now?
White and Nerdy
It is a dynamic variable compression in that the compression required to light off the majority of the chamber is higher than the fixed compression ratio of the piston motion. Reaction one is used to create the conditions for reaction two. |
White and Nerdy
One more attempt in case that doesn't stick.
In the conventional engine the spark creates a higher temperature as the source of ignition, heat radiation is how the reaction spreads through the combustion chamber. In this Mazda engine a small reaction in the combustion chamber creates an increase in pressure, and compression is how the remaining fuel/air mixture burns. So in the conventional engine it is heat radiation for ignition at a given compression. In this Mazda engine it is heat radiation with a small part of the chamber in fuel air mixture ratio 1 that is ignited. This combustion expansion changes the compression ratio for fuel air ratio 2 that fills the remaining area of the chamber. This change in compression ignites fuel air ratio 2. So the part of the chamber at fuel air 1 ignites by heat at compression level A, the part of the chamber at fuel air 2 ignites by increased compression to compression level B. The compression ratio for ignition of fuel air 2 is higher than that of fuel air 1. Fuel air mixture 1's combustion is used to control the compression of fuel air mixture 2. If you spray food coloring into water, there is time for it to dissipate to median levels. The second injection of fuel does not have time to mix with the remaining part of the chamber. This results in two different fuel/air ratios in the chamber at the same time, one of which is used to raise the compression of the other. Last edited by Tervuren; 07-31-2018 at 07:45 AM.. |
