CVCC. And with a carburetor!!
Andy D. Currently driving 2005 Audi A4 Currently driving 2006 Ram 1500 sometimes |
Cars & Coffee Killer
CVCC used a rich mixture on one side of a perforated barrier (which had its own valve) and a lean mixture on the other side. The rich mixture is used to ignite the lean mixture.
Mazda is using a small rich mixture just in front of the spark plug to compress the remaining lean mixture without a barrier.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." Last edited by legion; 07-31-2018 at 10:19 AM.. |
I need pictures:
Mazda's SPCCI compression engine: Here's how it works https://www.mazdausa.com/why-mazda/skyactiv
1996 FJ80. Last edited by Seahawk; 07-31-2018 at 10:48 AM.. |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
White and Nerdy
I would think that any gains that an opposed piston engine would be able to muster from more efficiently capturing combustion energy would be lost from more complicated mechanicals (two crankshafts, for example).
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
The first time I went through training on the SH-60 was in 1984...very rudimentary slides but lots of words to describe systems, which we were tested on. I of course memorized how everything worked but really didn't understand the more esoteric systems, like the fuel control system. Going back through a shortened syllabus in 1994, they had computer animations of all the systems and it was the first time I really understood the complex interactions. I get what Mazda is doing and now understand the concept.
1996 FJ80. |
Did you get the memo?
I was involved in some testing of a horizontally opposed 8 cylinder diesel aircraft engine that had a single crankshaft. The cylinders were staggered slightly and shared a crank journal if I remember correctly. Very cool product that is slowly making its way towards certification.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Extra crankshaft but no valvetrain.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Matt, do you have a diagram? I can't picture how you can have horizontally opposed cylinders with only one crankshaft.
Infiniti has been selling cars with it's variable compression engine for a year now.
http://forums.pelicanparts.com/off-topic-discussions/944574-variable-compression-engines.html
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 |
Sadly no, it's been at least 5 years and there's not much online in terms of public information. Like I said, I think they were slightly offset such that the opposed cylinders shared a crank journal but it's been a while.
Still here
Mazda is doing interesting work here combining the spark ignition and diesel ICE techs ... compress the fuel to almost the point of self ignition, inject a tad more into the vortex and ignite the center, creating a compression wave which ignites the rest of the fuel ... more power, more torque at lower rpm, improved efficiency.
https://spectrum.ieee.org/transportation/efficiency/mazdas-new-skyactivx-engine-gives-new-life-to-internal-combustion Last edited by pmax; 11-27-2019 at 07:57 PM.. |
I friend of mine has and drives his 1999 Honda Insight as his commuter vehicle.
He get 60 MPH even today. The battery pack is dead. He has to pull the fuse to the system to get it to start and run, and withing a few minutes the error lights come back on, so he is running on just gasoline. He plans to maybe pull the battery pack and guys on the internet have figured out how to test each cell of the pack, and replace the bad cells. He said it is a slow and tedious process. He said people ask him more questions about it than any of his Porsches. Many people ask if he built the car himself, as they have never seen one like it.
Glen 50 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
White and Nerdy
There are very competitive males I know that track these things, and are all out to beat eachother. The end result is they pay attention to their driving, look ahead, and do their best to maintain momentum without giving it up. |
Bland
Anything with a turbo is variable compression...
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
FUSHIGI
Cults require delusions. |
FUSHIGI
Turbo Corvairs showed up in 1962.
repost: selectable squish
![]() Raising an engine’s compression ratio improves fuel efficiency during low-load operation, but it can also lead to catastrophic detonation when maximum power is requested. Engineers have long sought to navigate this challenge with a variable-compression-ratio engine, and Infiniti promises to implement its solution in early 2018 with a complex system of links in the crankcase. There’s more than one way to skin this cat, though. German powertrain engineering company FEV proposes a piston wrist pin that passes through an eccentric bushing at the top of the connecting rod. As the bushing rotates, the piston moves vertically relative to the rod, in turn adjusting the compression ratio. The position of the bushing is determined passively by a pair of miniature pistons inside the connecting rod that rotate the cam in reaction to combustion and inertia forces. FEV’s 1.7-liter turbocharged inline-four demonstrator can adjust its compression ratio from 8.8:1 to 12.0:1 in 0.2 to 0.6 second.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI 25 John Deere X-590 Last edited by stevej37; 11-28-2019 at 09:33 AM.. |
I bet that puppy ain't cheap.
