Brew Master
Went back and read his post.
Nick Last edited by cabmandone; 11-02-2018 at 03:50 AM.. |
Thats good advice. Careful removal is key. Make sure you check for punky spots in the corners and bottom, no point putting a new window in a rotten frame. I've seen too many 'pros' just slam in the new units and not care one bit about long term.
I wouldn't get hung up on trying to fit a standard size. Near as I could tell, unless you're building a new house, the windows will all be custom sized so it's not big deal.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Did you get the memo?
Really the only advantage of standard sized windows is that if you can find stock sizes, they are less money.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
A couple things to consider, I haven't seen anyone mention the city/county rules for window replacement. If your area is like mine they even have rules on how to scratch your ass so I would check. In our case the city of Chula Vista says as long as the building's window opening is not changed then you do not need any permits. That is why we used custom made windows that slid over the 1/2 inch protruding aluminum old window frames. We lost a tad amount of opening size but not enough to notice. Plus we gained windows we can pull out and clean both sides of the glass.
Secondly, if you do this, a sealer made for installing windows and the stuff we used was not in a Home Depot or Lowes and has a 30 year life span so I guess the high cost of it is well spent. Use a LOT and remove excess later, way better than trying to add more. |
Zeke
By retrofitting, do you mean replace just the IGU (Insulated Glass Unit)? Thanks Quote:
Team California
Why exactly are you replacing all windows? Are the old ones rotting or broken, or just stuck? Do the old one not insulate well enough?
I used to make my living restoring windows on very old houses, both hung windows and ones that swung open or slide open. They can almost always be restored to function like new if they were of quality in the first place. A 1953 house would not be an old house in my world, however. I worked on pre-war stuff, back to the late 19th century. Can you post some photos of the offending windows you plan on replacing? Sometimes replacement is a smart move, especially in extremely cold or hot locations where R-factor can be improved dramatically. Still, I've seen a lot of beautiful original windows ripped-out to install cheap, schitty vinyl or plastic windows from some warehouse in China. To me, it's like replacing the interior of an old 911 w something from Autozone because the seats needed to be rebuilt. There are of course very high-quality replacement windows as well. Further info needed.
Denis Last edited by speeder; 11-02-2018 at 08:51 AM.. |
Yep. This is what my window guy calls "inserts." They are complete double hung windows with thinner frames that fit inside the current window frame. Cost of installation was half that of removing the entire window and installing new ones. No reflashing the brick an no replacing the window trim.
Superman, get us some photos. This way we can see and offer suggestion.
Look into clad windows. They are great. |
Here pics of my windows with inserts. Pics are grainy because they are in the TV room where it's really dark. The finish on the inserts are darker cherry than the original trim, but actually don't match any worse than the original windows from 1972, which were stained pine. The final trim piece hasn't been installed yet, so you can see the space where the insert window fits the original frame. They needed to "float" in the frame because it wasn't square any more.
. Last edited by wdfifteen; 11-02-2018 at 09:30 AM.. |
Sent you a PM
No, an insert as discussed. |
