On Tour
Removing Window Tint
What have you had the best results with? Heat, what kind? Sun, hair dryer, steam, other?
I need to remove and looking for advice from the PPOT brain trust.
- 2018 Cayenne S 958.2 - 1988 Carrera 3.2 Coupe Marine Blue (SOLD) |
A good friend has been tinting professionally for years I spend a lot of time at his shop. He always uses a steamer to remove the tint. Then cleans the remaining glue with a high end razor blade he always tells me cheap blades scratch the glass.
89 930 Cab Black 11 Cayenne |
Put some ammonia in a spray bottle.
Spray liberally on tint film, and cover with black trash bag (pressing bag against window/film). Let sit in sun for a while, or use heat gun/hair dryer from the opposite (non-tint) side. Then use a razor blade in one corner to get started. Once you have enough film released to grab with your fingers, it should peel off cleanly in one sheet. If not, repeat above ammonia/trash bag step. YMMV... |
Ammonia. Exactly what Eric said. I’d heard that exact method several times before and did use it once and it worked well.
Control Group
goes without saying you want to have plenty of ventilation
She was the kindest person I ever met |
Another + for ammonia and trash bag in the sun.
If there is left over adhesive on a window with defogger lines you can use more ammonia and the blue no scratch scotchbrite pads. Have a few on hand as they get loaded with the glue. |
Cheap cloths steamer
82 SC Twin Plug 3.2 SS ,46 PMO
I bought a cheap clothes steamer at Walmart ($25) and removed 25 year old tint, worked like a charm.
Ole Skool - wouldn't have it any other way |
On Tour
Thanks for all the input. I have a cloths steamer so probably give that a go. The sun is not very warm in NM right now.
Team California
Super-fine steel wool, (like 000 or 0000), is the only safe way to clean residue off of rear windows w defrost lines. Use lots of soapy water, mix DW liquid w water in a spray bottle.
Denis |
Let us know how it goes. The tint on my DD is going bad. I have a buddy that does tint and when I asked him about pulling it off and redoing he informed me that he would gladly do new tint, but I wanted it removed I better bust out the steamer. 🤣🤣🤣
+ lurking - contributing
Just removed the (too dark) window tint on my 930 with a Shark portable steamer. The tint was perfect for South Florida, still in great shape, but in GA very illegal.
Using the steamer, concentrated output on a window corner first and lifted the tint with fingernail. The absolute key is to work slowly, pre-steam the area you are peeling back and make sure you are removing the tint and separate adhesive layer as well. Put a towel on the sills to catch drips, most portable steamers only put out pressurized hot water so there will be some runoff. Once I mastered this, each window removal took less than 10 minutes and little to no adhesive left. Ammonia on a cloth rag will clean up any leftover adhesive. It was actually a fun job, though still have rear window to tackle.
87 930 96 BMW M3 Coupe 89 951 08 Astra H Peugeot moped Last edited by William930t; 02-16-2019 at 12:48 PM.. |
1. More time/patience is required. 2. They can/will saturate everything in sight, and turn then inside of a car into a sauna (especially when working the back glass). 3. They can/will burn you easily. 4. It's the most expensive option, if you don't have one already. Quote:
As Cooper911SC mentioned above (and IIRC, hes a pro detailer), the blue (no-scratch) Scotch-Brite pads are a much better option for that task. Again, YMMV... Last edited by Eric Coffey; 02-16-2019 at 01:00 PM.. |
Retired Member
I rented a wall paper steamer at Home Depot to remove the tinted windows and marker lights on my Z06. It took 30 minutes to remove everything.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Team California
![]() Fine steel wool when wet stays together pretty well. I wasn't aware of a non-scratching Scotch Brite material, that sounds great for the job. As long as it's gentle enough, the defroster lines have their own coating that is fairly easy to damage and then you lose their insulation. Brian, the fact that the rear window tilts up in that 'vette makes the job 100 times easier and less unpleasant. Laying in the back of a sports car doing a raked rear window like that would not be fun. I don't like very dark tint on cars but it's awesome if it comes on a used car that was in a sunny area. It protects the heck out of the interior and you can just remove it, like you did, and either put lighter tint in or go without.
Denis |
Team California
Oh yeah, the steamer I bought was only about $30 online and I found that it was great for cleaning the interior in general. I also have a small extractor for carpet and upholstery but the steamer really loosens up stubborn dirt on door cards and handles, etc.
Denis |
well to remove mine i just used heat and peeled it off. For the remaining glue my brother brought home a little bottle of special remover for it and it worked great. I have no idea what it was called but im sure its available from most auto parts stores. Atleast the ones that supply shops
82 SC , 72 914 |
Retired Member
I didn't like the tint, it was to dark. The one thing I regret from removing the rear tint is now the reflection from the sun makes it hard to see the factory gps/radio When I had a 911 I used the same method to remove the tinted glass. Lying in the back like a pretzel to remove the rear tint, fun times.
I really need to remove the SUPER dark tint on my Mom's car, its all bubbbly on the back window and difficult to see out of..
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
