Why are the oil drain holes at a 45 degree angle?
Is it to create a mess on the floor/driveway? Cause it always creates a mess on the floor.
<iframe width="964" height="542" src="https://www.youtube.com/embed/2yY3WAveQho" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Yep, they're definitely trying to mess with ya.
Also on the Corolla. The oil filter is right next to a sizzling hot exhaust manifold :( |
My Mustang has the oil drain plug on the back of the pan at a 45º angle. I thought it was so that when I put the front wheels on ramps, the oil would drain to the back.
I like it when they put the drain plug above a skid plate or crossmember.
you guys have it easy, my Toyota 4Runner oil filter is screwed to the engine block upside down
you're welcome |
So you can keep your fingers near the top and not get them into the oil stream (especially when it's hot!).
It's so pedestrians don't get wrapped around the drain plug :D |
Use a shallow but large capacity drain pan with a wide opening...mine has a 16" dia. opening to drain into. Pretty hard to miss. |
http://forums.pelicanparts.com/uploa...1551915540.jpg Sorry for the hijack, but how many hose clamps can you fit on an upper radiator hose? |
I've always thought that the last of the oil to drain has the most dirt in it. Think of draining a swimming pool, all the crap is on the bottom. |
Also keep a eye out for double hump pans. My moms 80s cougar 255? Had a double hump pan. Engine got rebuilt because my uncle didn’t know.
Old RX-7's had an upside down filter too, you got used to wrapping a decent size rag around it as the seal broke to catch all the oil.. |
As for the original post, A c12 cat has it on the side and it shoots a 1 inch stream 3 feet to side. Talk about a mess if the 15 gallon pan isn’t in the right spot. 9 + gallons in the engine.
If you know how to change oil, it doesn't matter how far it "shoots" or how much comes out, it's easy to catch it. Step #1 is to make sure that you have a larger enough receptacle and that it's empty. It needs to be empty because if you are not sure how far the stream is going to shoot, you hold the container up and close to the drain plug and then gradually move it away and set it down where it needs to be on the ground. I do this all the time and never spill a drop, even from my 7.3 Powerstroke that releases 4 gallons of hot, dirty oil when the drain plug is removed.
| All times are GMT -8. The time now is 12:10 PM. |
