E21 BMW ac problem
PPOT braintrust I present my problem.
1981 BMW 320i. The AC compressor cycles on then shuts off if you try to turn on the interior fan blower, then both do not work. If I turn off the interior fan blower the compressor cycles back on, if I turn off the AC the fan will turn back on, both will not run together. I suspect there is a relay issue, cannot find which relay. Thanks in advance if anyone has personal knowledge and experience with this issue. Sent from my SM-G960U using Tapatalk |
From your description it sounds like the relay / circuit is not holding a load. I have seen time and time again the relay(s) 'work' but when 'X' load is placed the contact points will not flow enough amps to sustain current because they are pitted / corroded.
You should find which relay it is, replace it with correct amp rating ( it's printed on the side) they are inexpensive. If no success you'll need a schematic for that to start performing voltage drop tests to find the issue |
I think you are on the right track, I had a e21 for a while years ago, can't help you with the relay position but you should check the contact surface of the fuse also. Could be wired direct through the switch?
Actually 4-6 contains the answer I was looking for the AC Relay is on a dash brace under the right side of the dash, I was going crazy trying to locate it in the fuse box. I know where to look now. I figured the perfect 1st step was to replace the relay, I now know where to find it. |
| All times are GMT -8. The time now is 03:03 AM. |
