-   -   Splice a fuel line? squirrel damage (http://forums.pelicanparts.com/showthread.php?t=1030216)
Neilk 05-22-2019 08:05 AM
Probably a dumb question, but here goes.
I have a pinhole leak in a fuel line, probably due to a squirrel biting it. Has anyone ever used a fuel rated hose coupler to repair a fuel line?
Replacing the whole line requires dropping the gas tank. Just wondering if that ever done, or if I have to bite the bullet.
Thanks!
biosurfer1 05-22-2019 08:09 AM
possible? Sure, but gas and brakes are two parts of the car I never go cheap on. Catching fire or not stopping at highway speed don't sound fun.
Rick Lee 05-22-2019 08:23 AM
I always thought the problem with fuel lines was accessing the end points to R&R the whole thing. I had one in my '87 Carrera that required a lot of disassembly to R&R. The photos the shop took were frightening and the labor was many times the cost of the part. So, if I could have patched it, I would have.
fastfredracing 05-22-2019 08:28 AM
Do it all the time. What kind of material are you working with ? There is a repair for nearly every type of fuel line out there.
Obviously, access is usually the hard part .
VincentVega 05-22-2019 08:31 AM
What kind of car? Low pressure carbureted cars have lots of rubber hose and clamps. Simple enough to splice in a patch. Use spring clamps. Higher pressure fuel injection? Not so sure. Sure its not rusted or rubbing on something? You could cut out a section and splice in a new metal section but you'd need enough room for a tool to get new ends on the line. How much room do you have?
Tobra 05-22-2019 08:54 AM
Fuel injection use fuel injection rated rubber lines. Internal reinforcement, not the sketchy, cloth wrapped stuff.
stomachmonkey 05-22-2019 08:58 AM
If it's a steel line just weld it back up.
Shaun @ Tru6 05-22-2019 08:59 AM
I would remove line and bring it to a hydraulic shop for a proper crimped replacement of the entire line with some new Cohline.
Neilk 05-22-2019 09:05 AM
Thanks for the answer. I was looking for professional feedback. It’s some kind of plastic.
fastfredracing 05-22-2019 09:10 AM
They have repair kits for plastic line . There are reinforced unions you can use, and or a tool to push barbed splice fittings into the plastic and the correct clamps
They are a little pricey , and a little bit of a pia to work with, but I do it all the time
VincentVega 05-22-2019 09:51 AM
^I've used one too, wasnt sure about it but it didnt leak :)
fred cook 05-22-2019 10:30 AM
Replace the part and get on with your life! Not worth worrying over!
GH85Carrera 05-22-2019 10:57 AM
Just some JB Weld and duct tape will do it.
It certainly depends on the fuel line pressure and location. On my 911 the line from the fuel pump started to leak. The only safe true fix is replacement. That line goes from the pump up over the steering rack, down the tunnel, and exist near the nose of the transmission. Working with no room at all is no fun. That line is under high pressure and I was not going to patch it.
BoxsterGT 07-30-2019 01:09 PM
Neilk -
If you email me w photos I can advise you.
I make up Porsche replacement fuel lines almost every day and this is something you do not want to play around with.
That said, I do have couplers specifically for the Polyamide lines in a 911 if that is what you are asking about.
http://forums.pelicanparts.com/uploa...1564517296.jpg
email me at: Len.Cummings at verizon.net
Arizona_928 07-30-2019 01:57 PM
LOL
:rolleyes:
Neilk 07-30-2019 02:27 PM
Originally Posted by BoxsterGT (Post 10541386)
Neilk -
Thanks for the offer. I brought my BMW to a local shop and they used a coupler to fix the line around the leak. No more gas smells, so holding tight.
BoxsterGT 07-30-2019 02:58 PM
:p
Good thing you brought it there.
Don't do BMW's. Only Porsches.
Len
pmax 07-30-2019 05:57 PM
BMW w/edible fuel lines ... figures.
What's next ? Organic impellers ? Wait ...
wdfifteen 07-30-2019 06:22 PM
Squirrels chew through a steel fuel line?
Oh. Yeah. Texas squirrels. :)
fastfredracing 07-30-2019 06:33 PM
Had this car in a few years ago.
http://forums.pelicanparts.com/off-topic-discussions/933809-what-eating-honda-accord.html?highlight=eating+gas+tank
