vash's Avatar
PPOT - Braintrust question.
i'm gonna unplug our office alarm backup batter and plug in a new one.
some cheapo HoneyWell system. shows low battery.
this is for my office. to do it officially - i need, official request from 3B-1254-(rev.2.0), sent in triplicate, approval forms returned in triplicate with wet signatures, peer review, 3 lowest bids, mock set ups, dry runs, contingency plans....
the battery is $21 bucks on Amazon. i'll take a long lunch break as compensation.
how may ways can this go wrong? i cant see a reset button. i could jump it and keep the system seeing voltage the entire time..i think i saw how he did it on that movie "HURT LOCKER"
figure i'll run it by you all before i cripple my work office because we hate paperwork.
thanks.
poof! gone
Old 06-12-2019, 03:24 PM
vash's Avatar
i cant believe there's me on this forum, and there is a dude rebuilding a Class A RV from scratch..
poof! gone
Old 06-12-2019, 03:26 PM
id10t's Avatar
I wouldn't do it ... could loose settings, etc. How farked would you be if Things Went Wrong and "They" found out you were responsible?
File work orders, email the boss, whatever. Make it someone else's problem.
Old 06-12-2019, 03:30 PM
It's a backup battery, right? As long as you maintain power to the system, replacing the battery should be a non-issue. Look up instructions for your particular model on Google or YouTube.
Guy
'87 944 (first porsche/project car)
Old 06-12-2019, 03:36 PM
MBAtarga's Avatar
Vash - don't forget the TPS report when you are finished!
Mark
'83 SC Targa - since 5/5/2001
Old 06-12-2019, 03:47 PM
Band.
Google it then just do it
1983 SC Coupe
2020 Macan Turbo
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 06-12-2019, 03:49 PM
peppy's Avatar
Is it a vista system?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 06-12-2019, 04:03 PM
Eric Coffey's Avatar
Unplug old one. Plug in new one. Done.
If for some strange reason it triggers the alarm, quickly leave the area while shouting "wuzzint me!"
Old 06-12-2019, 04:45 PM
This ^^^^^^. If it is the backup for security system, someone will have to access the system via the system code to reset the date, time, and other info that's ongoing as the system runs when you unplug the old battery. So if you maintain the power as you do the change over, you should be good to go for another five to seven years or more.
Marv Evans
'69 911E
Old 06-12-2019, 04:50 PM
gwmac's Avatar
Will take 24hours for unit to do a battery test then you can run your disarm code and it will reset.
It will not alarm when you unplug the battery, Batteries are 12 bucks at the supply house.
Old 06-12-2019, 04:54 PM
vash's Avatar
Haha.
Old 06-12-2019, 05:11 PM
vash's Avatar
Haha.
Old 06-12-2019, 05:12 PM
Send a message via AIM to fintstone
If you have a battery fault, your battery backup is most likely not working anyways. Even if you disconnect power briefly, it will likely just see it as a temporary loss from the power line (like a brownout). I have done this quite a few times myself without problem. Unless you are securing the crown jewels, it is unlikely your system is spohisticated enough to care (intentionally)...to prevent false failure.
Still...be stealthy and be prepared to disavow knowledge if necessary as noted above.
Old 06-13-2019, 04:32 AM
Banned
I'd hire a cute college intern just for that purpose .
WTF is wrong wif y'all?
Old 06-13-2019, 04:39 AM
He is a local gov employee. Services performed by interns are likely limited to Lewinskis.
Old 06-13-2019, 04:53 AM
gwmac's Avatar
Batteries typically last 3 to five years then fail the alarm panel load test. I have dealt with hundreds of these honeywell panels and have only seen a couple with a bad charging circuit, in fact they are some of the most reliable electronics I have worked with.
Old 06-13-2019, 09:41 AM
If there is a problem....
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Who, What, When, Where, Why and How.
Old 06-13-2019, 10:49 AM
Our household alarm has the battery backup as well. The panel will send me an alert that the battery is NFG, and I go get a new one. As soon as I disconnect it the "tamper alert" goes off, and I get a text and email, connect the new one, and another tamper alert, one more text and email, and I am done.
If you know the phone number for the monitoring company, call them first. Tell them you are going to replace the battery, and they can put it in a mode that is proper for replacement of the battery. Then tell them all is fine, and they will put it back to normal mode.
Old 06-13-2019, 10:56 AM
Gon fix it with me hammer
svandamme's Avatar
just pull the old battery on a friday afternoon when nobody is watching and vacate the premises..
they'll think the old battery just dropped voltage causing the alarm and somebody will replace it for ya
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-13-2019, 12:48 PM
Vaccinated and Boosted
mgatepi's Avatar
Originally Posted by 93nav View Post
if there is a problem....
deny everything; admit nothing; and always make counter-accusations
this
2013 911 Turbo S
2025 Lexus TX350, 2024 Honda CRV Hybrid
1930 Cadillac V8, 1991 Ford F250,
2023 Chevy Colorado
And some garage space....
Old 06-13-2019, 01:02 PM
