What is up with this clutch pressure plate ?
Was just getting ready to bolt this car back together, and upon opening the box, found this curious hole in the pressure plate .
Brand spankin' new Sachs clutch kit. I've done hundreds upon hundreds of clutches in my life, and have never seen a hole drilled into the friction surface of a pressure plate . I'm not comfortable using it . This is not from our host . Ever seen one like this ? It looks like something is pressed into the hole, but it does not correspond with any rivets or bolts in the back side . I think the mill missed its initial target when it was made . ![]()
No left turn un stoned |
Guest
Posts: n/a
Mallory metal for balancing? Never seen that before.
Model Citizen
I'd imagine if you called Sachs, they might say it's for balancing the assembly? Weird.
In the bottom picture lower left at the surface finish, it looks like it's pitted, but I assume that's just staining?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Looked chipped in that lower left pic to me.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Looks like a great place for a crack to propogate, then explode and destroy everything in its path.
I sent an email to sachs. Curious to hear what they have to say .
Strange place for a balance hole but likely won't affect performance. Think drilled brake disks (which do crack but very rarely explode).
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
14 hours labor to in and out it . Im not taking any chances. Its a p car . Not worth the risk in my book . It looks like it is drilled all the way through.
Im thinking it spins a whole lot faster than a brake disc also .
Control Group
that ain't right
Drilled rotors the holes are chamfered, that one looks like it has burrs around its periphery
She was the kindest person I ever met |
From Sachs. -Hello,
Thanks for contacting ZF Sachs in regards to our 3000 970 010 and your 997 4s. Yes the hole in the pressure plate near center is correct, I can see it in the stock image used for cataloging. I looked at our sales history and see 1,800 kits sold with this pressure plate without any complaints. Not sure what the hole is used for, possible manufacturing as an alignment hole. . Im still waiting for another tomorrow .
Counterclockwise?
I would think this had gone through QC check for balancing etc. and someone would have caught it?
There all kinds of heaps and valleys in the clutch. But I have no idea.... Edit (I was typing at the same time as Fred)
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Good eye for quality. I agree. Weird and not worth a 14 hour gamble.
Model Citizen
Needs a Vonnen Shadow Drive.
Fred - I see no reason why that hole should be there.
I could be wrong (there's always a first time ) but I think you're right to hold off.Please keep us posted and good luck....
Old dog....new tricks..... |
Almost Banned Once
It could be a CIA tracking device
- Peter |
Senior Member
Yup.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Fred,
We're doing the same job in our shop today. The Sachs pressure plate we got has no such hole I've not ever seen one on the friction surface
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
"The hole is correct"... Bull****
especially where the disc's friction material is at. I see that part blowing up causing a very bad day.
dolor et pavor Copyright |
Don't use it. Seems like that hole would wear a ridge all the way around the clutch disc.
I will be interested to read up on what Fred hears in the follow up response. |
