Information Overloader
Thank you.
Rick,
I used a 16d nail as a spacer between my deck boards. I'd probably use a smaller size nail next time.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Here's mine I built last summer
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Here's an old photo of a deck I built for my neighbor a couple houses down from me. I like random.
![]() No, not the trash can guys |
Model Citizen
Except for my house, I don't think I own any one thing as valuable as that deck. Teak? SS fasteners?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Red Balau, trade name Mangaris, harvested from Indonesia. Its just typical color coded trim head deck fastener. I always face screw my deck board making repairs easier in the future if a piece of decking needs to be replaced. Hidden fastener can be a PITA, but they look good though.
Thanks Paul I will also check with the lumber yard to see what they recommend .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Home of the Whopper
No gap.
Pressure treated lumber shrinks a good bit.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
^^^ A novice here....but that's what I'd do too.
Evil Genius
45 degree heringbone it
Life is a big ocean to swim in. Wag more, bark less.
I spent an hour this morning measuring and getting a picture in my head. I am pretty sure I am going to do the picture frame setup . I will start with the blocking and get that in place . Then I will cut about 2 ' off the existing crappy deck boards so I can still walk/sit while installing the picture frame boards .
Then I will start pulling up boards and replace with 16 footers . I am a one man army so it will be a bit before it is done. Will take pics as I go along . Thanks for all the advice guys it has been very helpful . |
Unregistered
I say keep it simple
Parrothead member
Here is one I recently built. The customer originally wanted a diagonal or herrigbobe pattern. I talked them out of it because it would have been a a tremendous waste of decking material thst was very expensive. I always try to design and layout my decks to minimize material waste.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
That's beautiful, Vinny!
Old dog....new tricks..... |
Vinman that is a beauty ! Being retired I am careful spending the $$$ and I just can't justify the cost of composite . So it will be standard pressure treated 5/4 x 6 boards screwed down no nails. Will let it " weather " over the fall/winter and then stain in the spring . Wife and I are discussing color scheme but we're thinking light grey for the deck and dark grey for posts/ballusters and handrails .
I will post the before pics today , the ballusters/posts will be retained as they are in good shape . The hand rail cap will be pulled and replaced . |
Parrothead member
Thanks guys! Appreciate it. Couldn't get the other pics to load for some reason. Yeah composite can be $$. That stuff was around $5.00 a linear ft. There are very cheap composites out there, but they look like doo doo. I personally like wood better myself. My own deck is wood. Sure it takes a bit of maintenance, but looks so much better than plastic...
Platinum Member
I suspect by the time you add staining and sealing, composite is not much more.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Sorry to thread jack, but I've been looking to replace my front porch decking with something composite.
My main concerns is looks/durability. The porches face south and live a hard life: Sun, rain, sun, drought, repeat. The existing painted (unknown, but probably treated pine) wood decking swells, shrinks, cracks, peels, etc. They require regular maintenance (sand/caulk/repaint) and still look like crap. Is composite the way to go? And is Azek the right composite? While cost matters, looks, durability/low maintenance are more important. Total area isn't huge, ~5-600 sqft. Thanks |
